Hello
My name is Baldur and I live in Iceland. I have a 2003 Toyota Hilux with the stock 2KD-FTV engine and the stock R151F manual transmission.
I have modified the Hilux alot; long travel suspension with bilsteins coilovers front and rear, tacoma rear axle, custom wishbones at front, 38 inch tires, arb lockers etc. Here is a picture:
It is build for snow driving.
I am planing to swap a late version 1UZ-FE VVT-i into the Hilux, the engine would come out of a GS400, but I'm not sure that transmission combo to use. The options I see at the moment are:
1. use the standard Hilux R151F manual transmission and transfer case. This would give me good gearing for the snow. I have heard about problems to run the engine without the standard transmission, can anyone inform me about that?
2. use the standard GS400 A650 auto transmission and mix a transfer case on it. I am a bit afraid about the torque converter and gear ratios, has anyone used this combo for offroad, snow and crawling? Does anyone know if it is possible to fit a transfer case to the A650 transmission with out having to build an adapter?
thanks
Baldur
![382284_10151636422540432_331375738_n.jpg](https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-snc7/382284_10151636422540432_331375738_n.jpg)
thanks
Baldur
