Gonzalo Bravo
Hi again
I am trying to make run a JDM 1UZ FE second generation.
Specs are:
Ecu plugs: 34/22/16/28
Ecu N#: 89661-50241
B/R wire feed EFI and W wire feed sensors.
The engine starts, but when should down revs and continue in idle, it stops.
With or without MAF the problem remain the same
Enough Fuel Pressure
Spark is present
Fuel is present
Injectors are ok
This is the video where you can see that starts but stop inmediatly.
http://youtu.be/T5mJ4SKpwxU
Any idea???
Specs are:
Ecu N#: 89661-50241
Spark is present
Fuel is present
Injectors are ok
Any idea???
