who knows if you can get your usual 1UZ-FE and use the bellhousing / clutch assembly from a UZJ100 (landcruiser) to bolt the engine to this gearbox (H150F which is a landcruiser too) then adapt that to the transfer case (HF1A)? (by the way, the gearbox and transfew case come out of a HZJ80 landcruiser)
will all this work easily, or would it all be too hard to adapt together?
