1UZ-FE in 1996 Grand Cherokee
PM
Hi,
first , great site . get lots of helpful info for my engine swap.
just finished the swap and the engine works. still working at some minor problems .
right now I'm thinking about the gear ratio.
Engine LS400 1992 with original auto-gear mounted. running my GC as a 2WD right now. 99% on road driver.
Tires are 265/70-16
original ratio at my 1996 GC 4.0 is 1:3,73.
Now the GC is too fast for a SUV and to slow from zero and can not drive that fast in Thailand anyway. would prefer more power/torque from low speed.
want to change to 4.11 or 4.56.
any suggestions whats the better one ?
thanks
Heiko
Phuket Thailand
4.11 is what a Patrol runs.
I'd lean toward that as the 4.56 is pretty low.
My suggestion is get a rear 4.11 diff and try it and if it's still to tall try a 4.56.
At least a used diff centre won't be expensive. THey're one item that usually sell cheaply.
Interestingly I chnaged my Range Rover from 3.5:1 to 4.11 when I went to taller tyres (35") and it was just right.
thanks for the info,
as my original already is a 3.73 and I really miss the punch from the start , I thought I jump direct to the 4.56. but will rethink and maybe try the 4.11 first
there is no need for me to have a car that makes 180 or 200 km/h.
lot of stop and go traffic here and some steep mountains routes.
will list tomorrow a short list of my " minor" problems. hopefully will get some solutions here.
here's a pic of my GC
cheers
Heiko
Ok here are a list of my problems.
Gear ratio probably to long - working on it. will go for the 4.11
car runs on idle ( P/N ) perfect. revs on P/N up to the limiter without problem. sound smooth an strong.
putting in gear and start driving, hit the pedal and it starts choking. feels like not get enough fuel or pull a plug for a split second.
handle the gas-pedal careful and slow it works.
tochometer ( orig. jeep 6 cyl. ) starts working 900rpm and up . less than 900 goes to 0 or flickers 0-800. above 4500 jumps from 4000 -6000 and back. at the same time my Voltage meter jumps from 14V back to 10 for a second when rev. up from idle to 1200.
my original jeep on board computer states " transmission overtemp." even when engine is cold.
cheers
Heiko
