yea i rang them up and for the flywheel and a heavy duty push type clutch its dirt cheap, i couldnt beleive it.
do you know if this works with the adapter plate that goes from the r154 to auto bell housing?
MWP, do you recall if it's machined for the clutches for the later MK4 Supra with the 2JZ-GTE and V160 6spd, or the earlier MKIII with the 7M-GTE and R154 5spd?
If this is for the later model it could be interesting for us here in the USA, even with freight from OZ.
Im guessing its made to take the clutches used in early Supras (like the MA70 which used the 7M-GE and W58 'box).
It wont be the R154 supra clutch as thats a pull-type.
i could ring them again tomorrow to find out what model supra clutch they use. im pretty sure its the early type as its a push type cover.
does the v160 pressure plate have a differant boltpattern to older r154 cover? or bigger plate? as they sell the flywheel byitself and you could just use the differant plate and cover with that.
im goint to order the flywheel and clutch with my next stock order just too look at it.
