1UZ-FE AM wiring diagram
Marlon
i have checked it on web one week already but no result.
any one here has the wiring diagram for toyota 1uz-fe ECU (89661-3A080)
the plug is 34p 22p 16p 28p,thanks a lot!!!:):):)
please see this picture:
Well one thing I can tell you is that it's out of a '95 UZS151 Crown Majesta but can't help with a wiring diagram though
If you have the plug for the 28P socket it will have the tails of the wiring on it. Looking at the side that the wiring is on start from the top right which is pin one go from right to left numbering each wire and note the colours. Post up the results and some of us might be able to shed some light on the subject so you can make it go. It will take a lot of time but joys of these conversions
u need the 28 pin plug to be from same car that the motor cam eout of if u want to go by wire colours
have u got the 28 pin plug
have seen many motor wreckers/sellers dont supply it
i tried to get some of these plugs from japan but no luck
i think there are 3 or 4 differnet pin configs on 1uzs thru the years on the 28 pin plug
and most of the time i normally manually find out what msot pins do one by one
as the 3 or 4 power wires are easy to find
