I know the code 47 is sub throttle which is deleted for the install into my hilux.
And that the fix should be to jump the throttle Vc to the sub throttle VTA
but my ecu doesn't match the wiring diags I have found and I don't know what vehicle the engine/trans/ecu is from.
everything is running fine but the flashing light is really pissing me off.
Is it possible to identify the ecu from its' serial# so I can find the correct wiring/pins to stop the error code?
