1uz Dimensions.
BlownV8
After many questions and requests, i finally gave up and put a tape measure on a 1uz myself.
Here are the measurements i got, may be useful for anyone who is considering this engine, and is a bit short on space.
Overall Width Of motor, including dipstick - 650mm. Dispstick only about 10mm.
Overall length of motor, not including engine fan - 680mm
Height of motor. 590mm. This measurement is from the uppermost part of the sump to the top of the manifold, ie how much clearance you would need from your crossmember/steering rack to the bonnet.
Bellhousing mount is approx 380mm circle. It was 380 across and 380 high, and thiat did include the small protrusion for the starter motor sprocket.
Other Facts.
Tapper covers go back as far as bell housing mount.
Traction control module, if you plan on using it, sticks up about 15mm from manifold.
Engine mounts can be used on either side, except in front sump version, as you sump would sit on top of cross member.
Thats about it. If anyone else can add more useful data and measurements, feel free, the more info on offer for this moter, the more it will be used.
Adam.
Hey Adam,
Sorry I didn't reply sooner, but here's a few piccie's you might like.
I'm working on e new project myself, of which I can't give details but i had the same problem so I went out to a friend who imports *** engines to europe and did some measuring.
here it is! sorry second piccie is a bit blury, but there was beer also (measurements are accurate though :alcoholic
http://venixjr.student.utwente.nl/thomas/gallery/view_photo.php?set_albumName=proto&id=1uzfe_front_photo_measurement
http://venixjr.student.utwente.nl/thomas/gallery/view_photo.php?set_albumName=proto&id=1uzfe_side_photo_measurement
click on the pictures to see the large ones.
Grtz Thomas
