1uz 80 series auto
mick 490
Hi guys all info has been very handy. Am looking for a fan idler and pully to replace the hydraulic pump on my 1uzfe any help would be good, dont care if it is 2nd hand
pulled guts out of hyd pump to try and use it as an idler but not working. dont have hyd fan as am using ba falcon tiwn thermos
will a fan idler for a ls 400 fit the soarer 1uz-fe , also will a plug , lead ,dizzy cap and roter button for ls 400 fit the same engine
The fan idler and hydraulic fan pump units will interchange from 1989 through until 97/98 until they went to the VVti engine. VVti engine fan idlers can be made to fit with a small modifaction but are not a direct bolt on. There are a few different solenoids. Dizzy Caps , rotors and spark plug leads are the same except the LH coil lead is different from Gen 1 to gen 2 due to the changed position of the coil. Spark plugs change but there are a couple of different part numbers as on model of soarer runs a smaller gap.
