After hearing from Paul from Aeropc having his 2uzfe block cracked. I was little concern so I took a trip to my engine builder and we noticed the 2uzfe main have minimum support. Where the main caps attach have hole/s in both 2uzfe and 3uzfe. The 2uzfe have two holes at 10 O'clock and 2 O'clock. The holes are about 1" in diameter. However the 3uzfe block only have one hole in the center (12 O'clock). However, the 1uzfe (at least pre 1990) have solid main support.
From the perspective of the aluminum block, the 1uzfe is way superior then the 3uzfe. However, I am not sure about the iron block vs the 1uzfe. I think the 2uzfe would be alot stronger with an engine girdle to distritbute the stress to all mains instead of just one. We are working very carefully to produce an engine girdle for the 2UZ.
I will have pictures for thoes blocks.
