Probably won't fit, but I don't really know. I have only checked the other way around. Older igniters on newer engine and this was no good.
Find an older Corolla(AE92 87-89), or Celica (St18x). These should fit.
Part number 89621-12010 is what you need.
The 1UZ needs two igniters, one for each coil.
Each igniter has a five pin connector. The loom has the just the 2 connectors, one for each igniter. The igniters are mounted to a small metal bracket on top of each other. The bracket needs to be grounded too.
One connector on the wiring loom uses 4 pins(out of the 5) where as the other connector uses all 5 pins. The extra pin is the tacho output signal.
