CT20 turbo's are a lil bit yukky, but I see no reason for them not to work.
from memory they are found on 2.4L turbo diesels.
you will get boost early and also it will run out of airflow early too.
you can only but try them and see what happens.
It will work, it has no choice,
but you may get heat issues and compressor surge and perhaps if the wastegate's are not large enough, boost creep.
but it will work.
