Displacement | 2491cc |
Type | Twin Turbo Inline 6 Cyl |
Valvetrain | Belt driven DOHC 4 valves per cylinder |
Fuel System | TCCS EFI Premium Unleaded |
Ignition System | Direct fire ignition |
Combustion Chambers | Pent Roof |
Compression Ratio | 8.5:1 |
Bore x Stroke | 86 x 71.5 |
Peak Power | 280PS (206 kW) @ 6200rpm |
Peak Torque | 37.0 kgm (268 lb ft 363 Nm) @ 4800rpm |
Fuel Consumption | 210 g / PS*h @ 2000 rpm |
Dimensions (LxWxH) | 860 x 670 x 665 mm (MTM) |
845 x 670 x 665 mm (ATM) | |
Weight (complete) | 217kg |
Turbos | CT12A (2x) |
Compressor wheel | 37/54mm |
Turbine wheel | 52/42mm |
Boost | 0.60-0.69kg/cm2 (8.5 – 9.8psi) |
Fuel Injectors | 380cc/min high impedance |
Intake cam timing (o-c) | 3° BTDC – 41° ABDC |
Exhaust cam timing (o-c) | 46° BBDC – 2° ATDC |
Camshaft duration | 224 (in) 228 (ex) |
Valve clearance cold | 0.15-0.25mm (in) 0.25-0.35mm (ex) |
Spark plug | ND PK20TR11 / NGK BRK6EKPB11 |
Plug gap | 1.1mm (limit 1.3mm) |
Base Ignition timing | 8-12 BTDC (jumper TE1 E1) |
Idle rpm | 600-700 |
Engine Oil | SAE 10W30 API SH |
UPDATE: A limited supply of the original best-selling Lextreme 1UZFE EGR Delete Kit remains. If you own a 1UZ from 1990-1997, you really need to get this kit! Email me at [email protected] for help with ordering or questions. This will probably be the last kits I have made.
