| Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) Stand Alone ECU, Piggy Back ECU, Wiring, Tuning, Injector Upgrades, Air Fuel ratio, Fuel Pump, Ignition, FMU, FPR and any engine electrical/fuel component relative topics. |
Thread Tools | Display Modes |
#1
im going to be running an after market on my 1uzfe and that got me thinking
i have heard that you can get a lot more power from using separate throttle bodies im just wondering if it is worth going to the effort of doing this mod |
#2
There are much less expensive ways to make power! Exhaust and a good tune.
From my own searches on here Ive often read that you cant really reap the benefits of ITBs without dropping in cams and maybe even doing a bit of head work. what other mods have you got done/doing?
__________________
200.3 rwhp... dyno'd on 35" mud tyres! N/A, twin throttle, extractors and cheap copper plugs! |
#3
have made new exhaust manifold and exhaust system
thinking about getting a link computer but might use standard ecu not really sure any ideas on getting good power with out spending heaps and heaps of money wanting value for money alone with power increase |
#4
you'de be much better off putting the money into a decent ECU and dyno time than the money you put into ITB's... they can be horrendously expensive.
And if you do have a bit of disposable income to splash out on it later I'd consider cams and a bit of head work including upping the comp before ITB's.
__________________
#5
ITB's can make a large difference, but not with the original manifold.
http://www.a1turbos.co.nz/eight.html Agree it is not cheap. Dyno figures are from our STANDARD engine with 50mm ITB's, dry sump and open exhaust headers. [/IMG]
__________________
'The more I know, the more I know what I don't know' |
#6
from what i understand the factory manifold is crap
so is it possible to change the factory setup to a new type using the existing v8 throttle body to achive a similar increase in power |
#7
Wouldn't say the factory manifold was 'crap'. It meets the requirements of the market the engine was meant for. Not meant for 'rev heads' like you and I.
Major problem for performance is the abrupt angle change at the manifold/head interface. A single plenum will not give the same or close results. Air pressure at the valve will be lower, and when one valve is about to close and needs to ram the last bit of air in, another valve opens and lowers plenum pressure. So far as cost effective ? 'How fast do you want to go ?' - 'How deep are your pockets ?'
__________________
#8
ok well ill go with the individual throttle bodies can't think of a better cost efficient way to increase power
#9
The other point I forgot to mention.
ITB's need a GOOD aftermarket ECU. They MUST be mapped from throttle position, be sequential, and have variable injection timing.
__________________
#10
Probably the most cost efficient way to increase power is nitrous, as long as you don't overdo it. ;-)
__________________
High mileage, low compression, and sometimes not firing on all cylinders, just like my cars..... Supercharged Supra Project BMW V12 Project 2JZ-GZTE Project |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Where can I buy radiator cores and end tanks | quadcam boat | Fabrication (Members Only) | 2 | 06-16-2006 01:22 AM |
| Accessory Belt Replacement 4.7 Tundra | ericj516 | Diagnostic & Repair Tech | 6 | 03-23-2005 02:34 PM |
| Toyota Diff ratios | Lambo | Drivetrain (Members Only) | 10 | 12-08-2004 10:50 PM |
| Multi-Layer-Steel Gaskets Available | Miles B | Forced Induction Tech (Members Only) | 7 | 07-08-2004 11:34 AM |
| Did I just buy the wrong half cut??? | 1UZ-HZ | Swap, Conversion, Transplant, Specialty Vehicles & Project Diary (Members Only) | 20 | 03-23-2004 04:23 AM |
