Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Forced Induction Tech (Members Only)
Custom Search
Forced Induction Tech (Members Only) Supercharged, Turbocharged, NOS, Intercooler, Methanol Injection & Go Fast and None OEM Stuffs.
Reply
Thread Tools Display Modes
  #1
Old 02-08-2005, 10:01 AM
LTLRKT LTLRKT is offline
Kinder
Default Individual Throttle Bodies for FI
I just had the idea of ITB as we are making a completly custom intake for the turbo setup. So have 8 ITB with bellmouths enclosed by a large plenum chamber, instead of a large single TB...
Any thoughts on this from any one? Anybody running ITB's on the 1uzfe?
Riste.
  #2
Old 02-08-2005, 02:25 PM
ozaristov300 ozaristov300 is offline
Kinder
Default
Riste.
Ring Kerry Mitchell on 0417 516 997. He is also in Melbourne Australia and just happens to have a full set of throttle bodies and trumpets surplus to his requirements. Obviously you will need to manufacture your own plenum chamber to encase them but the hard work's already done.
__________________
Life is too short to drive crap cars
  #3
Old 02-08-2005, 05:26 PM
Zuffen's Avatar
Zuffen Zuffen is offline
Super Moderator
Default
The set-up you describe would put the t/b's after the blower, is that right?
If you put them in front of the blower theres no point as you would be feeding the airflow through 8 itb/s then one compressor then back to 8 manifold runners.
Assuming you put them after the super/turbocharge there could be a nominal increase in performance I couldn't see it being worth it.
Would you house the ITB's inside the plenum of have the plenum on top of the itb's. If the itb/s are inside the plenum you'll find them impossible (or near enough) to adjust/work on whilst if on top it will be very hard to mount solidly plus how would you hang the blower off it? If running a turbo the mounting is a little easier.
Remember you need to seal the plenum to all 8 itb/s well enough that they do't leak under 15lb of boost.
Lastly as the itb's are after the blower when you tried to shut the throttle the pressure may try to keep it open.
Lastly think of the pressure waves inside the blower as you shut the throttle.
I've never seen or heard of the throttle being placed after a supercharger and probably for those reasons.
__________________
Rod
Engineering by Bodge.
We may be rough, but at least we're expensive.
  #4
Old 02-08-2005, 05:56 PM
thefastj thefastj is offline
3rd Grader
Default
still use the one throttle body outside the plenum... but set up inside the plenum like this:
http://www.fedrelandsvennen.no/amcar...ilder/hot4.jpg
all that has a plenum cover to fit over it with throttlebody outside.
__________________
"C'mon, we got some catchin' up to do."
  #5
Old 02-08-2005, 10:13 PM
MaxPower MaxPower is offline
2nd Grader
Default
Quote:
Go take a look at 95% of centrifugal blower setups or almost any EFI turbo setup - i can't think of any i have seen recently that are draw through, we have BOV's now so ur car can sneeze everytime you change gears :roll:
  #6
Old 02-08-2005, 10:21 PM
chrisman chrisman is offline
3rd Grader
Default
hi guys, i have had some experience with ITBs.. they were on a 4age that i had turboed.. they originally came on the engine which is the 1.6 20 valve.. these itbs can be had for reasonable dollars.. anyway, i had great success with the project.. with 4 additional injectors--using the original toyota ecu and a toyota ct26 turbo from a supra--the car ran a best mph of 118 in the quarter at 13.0 on street 185s in a front drive paseo..
anyway, they worked very well, and il post some pics of the 4 additional injectors plumbed in- and the fabrication in progress..
2 of these setups could work very well on a 1uz..
  #7
Old 02-08-2005, 11:14 PM
Zuffen's Avatar
Super Moderator
Default
When I referred to no superchargers blowing thru a t/b I was referring to real superchargers.
A centrifugal is really a belt driven turbocharger.
I seriously think itb/s make a simple plumbing operation complex.
__________________
Rod
  #8
Old 02-08-2005, 11:48 PM
autronic's Avatar
autronic autronic is offline
Moderator
Default
Zuffen:
The reason to use ITB is to get better drivabillity in off/on/off boost situations. The current crop of WRC rally cars is an good example.
  #9
Old 02-09-2005, 06:17 AM
Kinder
Default
Buddy,
What are you on about??? What blower? And Why on earth would you put a throttle body infront of any sort of Forced Induction Device????? How the hell is that ment to work? Put it inside the engine???? LoL
Also to thefastj. I was originally going for the bellmouthed runners and a single 115mm throttle. But i beleive you would get more "surface area" intake with eight 48mm throuttles, which to me means more air, faster, smoother - more power? More response?
Oh and thanks ozaristov300, will call him tomorrow!
  #10
Old 02-09-2005, 01:29 PM
Zuffen's Avatar
Super Moderator
Default
LTLRKT,
Don't know why you would put a throttle body in front of a blower.
Must be all those photos I've seen of AA Fuel Dragsters, Eaton fed Holdens and every other Eaton, Whipple etc set up I've seen.
T/b's go after turbo's and centrifugal compressors (the same compressing principle) but always before positive displacemnet blowers.
Suggest you look at Gary Meyers twin blown Mustang. Throttle before the blower. Perhaps he put it there because he didn't know any better? He should have checked with you first.
__________________
Rod
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
individual throttle bodies toyotasrfun Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) 2 03-22-2009 03:59 PM
my individual throttle bodies for my 1uz : DenZel Engine Modifications (Members Only) 54 10-12-2008 11:17 PM
Two Different Throttle Bodies SC400TT Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) 3 02-13-2008 11:02 AM
individual throttle bodies madmonkey Fuel, Ignition, Air, & Tuning (FIAT) (Members Only) 14 07-23-2007 01:02 AM
Double Throttle Bodies ToranaJudd Forced Induction Tech (Members Only) 17 04-30-2006 12:01 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
