Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Forced Induction Tech (Members Only)
Custom Search
Forced Induction Tech (Members Only) Supercharged, Turbocharged, NOS, Intercooler, Methanol Injection & Go Fast and None OEM Stuffs.
Reply
Thread Tools Display Modes
  #341
Old 04-20-2008, 02:18 PM
kc95sc400 kc95sc400 is offline
5th Grader
Default
Quote:
Originally Posted by JustenGT8 View Post
What tyre pressure did you run?
On street tyres, a manual box and a 2.92:1 final drive i still managed a 1.7 60ft. With an auto you should get me there I dropped pressures down to 18psi and gave the tyres a fair warm up skid
About 26 psi. I'm looking for some wider wheels to put wider tires on. I'm thinking 255's. I'm currently on 225 BFG's.
I went back to the 1/8 this past Thursday and ran an 8.79, pretty good improvement. I really think I would do MUCH better with some more rubber in the back, I can't launch anywhere near my 2800 rpm stall without massive spinning.
KC
  #342
Old 04-20-2008, 05:02 PM
JustenGT8's Avatar
JustenGT8 JustenGT8 is offline
Bachelor
Default
26psi is waaaaay too high. Drop to 20psi and you'll pick up nearly 0.5 secs
__________________
Justen
Twin Turbo UZ Group A ST185
Twin Turbo UZ Group A ST185 Thread
  #343
Old 04-20-2008, 05:21 PM
5th Grader
Default
I'm slightly worried about the tire coming off the rim with that low of air pressure!
I'll wait and see what happens when I get some more rubber in the back, then, I may just take your advice if needed. It would be so awesome to run a sub 8.5 second pass, in a Lexus, at a drag strip populated by rednecks! (no offense to any rednecks that may read this, LOL)
KC
  #344
Old 04-20-2008, 09:08 PM
JustenGT8's Avatar
Bachelor
Default
Tyre will be fine unless you have really shitty rims? All straight line remember.
Mine run was down the full 1/4 so i was pulling 122mph through the traps with 18psi tyre pressures in my daily driven street tyres...no issues. You will have no probs at all.
__________________
Justen
  #345
Old 04-21-2008, 02:20 PM
striker's Avatar
striker striker is offline
6th Grader
Default
we have mini's spinning the rim inside the tire because of low presure, I can't see it comming off though.
grtz Thomas
__________________
Finnished a GD-T70
  #346
Old 05-03-2008, 08:31 AM
5th Grader
Default A few quick updates
Thanks to Scott, I have purchased a set of TT wheels, should be here Tuesday. I have also ordered 4 Sumitomo HTR III tires which should also arrive on Tuesday. 275 40 17 for the rear and 245 45 17 for the front. Again, best case, I'll be able to launch at stall with the throttle wide open. Hopefully with the 275's and the slightly heavier wheels (I'm assuming the TT 17's are slightly heavier?) I'll launch without spin.
I will likely be going to either a 1/4 mile track on Wednesday or back to the 1/8 mile track on Thursday.
In anticipation of being able to lauch at higher RPM, I finally decided to install the transmission fluid cooler I've had laying around forever. I'm actually using two coolers, the second one being the OEM hydro fan cooler that was removed. The fluid circuit is like this - transmission to OEM cooler in the radiator - to the aftermarket cooler, which is mounted to the front side of my intercooler - to the recycled hydro fan cooler, mounted in somewhat the same position it was originally, but on the passenger side - back to the transmission. Should decrease transmission temps quite a bit!
I'll update with some pics and new times soon, and, hopefully some track videos!
KC
  #347
Old 05-09-2008, 12:26 PM
spf_lexus's Avatar
spf_lexus spf_lexus is offline
Bachelor
Default
Im about to finish my "fish" project and just wanted an idea of the daily drive ability of my 91' LS400. I have a modified exhaust w/ (2.5'' w/ Y pipe and 2.25'' from mid cat to headers. I will be using a centrifugal SC in conjunction w/ a 3000rpm stall TC. I wanted to know if anyone feels that this 2.5-2.25 switch using the mods listed will still give decent mid range power. I know 2.5'' is too bug but i will use FI and use half the 2.5 and half 2.25. any ideas???
__________________
1998 GS400 VVTi Diamond Pearl White. Tein Flex coilovers 16k/12k, OS Giken LSD, Figs Engineering spherical caster arms + 34mm front RCA + MEGA/Toe/Traction arms + rear knuckle sphericals, front/rear end links, TRD sway bars, Serialnine solid subframe mounts, Serialnine Widebody kit, TOMS 6-link kit, TOMS front under brace, Ikeya Formula RUCA's, JIC dry carbon strut tower bar, custom HKS/Burns stainless exhaust, PPE headers.
Soon to be supercharged and intercooled...
1991 LS400 grey supercharged: Retired
1993 SC400 grey supercharged: Retired
1992 LS400 silver: Retired
1995 SC300 green: Retired
1993 LS400 white: Retired
  #348
Old 05-15-2008, 09:22 PM
5th Grader
Default
Quote:
I don't see you having any problems with your exhaust, but I'm not an experet. It sounds a little similar to my exhaust. Mine goes manifolds (don't have headers yet) - factory y - h pipe where the 3rd cat was - dual 2.25 back to a pair of small resonators - 2.5 inch back to a pair of Dynomax mufflers.
I have a 2800 rpm stall. My car is my daily driver.
KC
  #349
Old 05-15-2008, 09:27 PM
5th Grader
Default
Sorry to take so long to update.
I put on Supra wheels with 275 - 40's in the rear and 245 - 45's in the front. Went back to the track and I still can't launch worth a damn even with 18psi in the tires. I'm spinning the 275's by 2200rpm.
Currently keeping an eye out for some slicks..
KC
Couple of pics. Pic of car with Supra wheels. Pic of a very small sample of the rubber from the 275's!
  #350
Old 05-23-2008, 09:57 PM
RedPhoenix's Avatar
RedPhoenix RedPhoenix is offline
5th Grader
Default
So... since no one has posted much. If you could of done a few things differently.. what would you have done?
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1UZFE Soarer engine into a HQ Holden Craig Swap, Conversion, Transplant, Specialty Vehicles & Project Diary (Members Only) 0 02-09-2006 09:37 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
