Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Forced Induction Tech (Members Only)
Custom Search
Forced Induction Tech (Members Only) Supercharged, Turbocharged, NOS, Intercooler, Methanol Injection & Go Fast and None OEM Stuffs.
Reply
Thread Tools Display Modes
  #261
Old 01-30-2008, 06:39 AM
kc95sc400 kc95sc400 is offline
5th Grader
Default
Quote:
Originally Posted by 1uzvl View Post
Lexplay,i would be real keen to eyeball your setup when you get it done if you would like to show it off.Im at the stage of a turbo/supercharger showdown and i think the supercharger setup is winning.My vl is just begging for some boost and a nice vortech supercharger with the straight cut gears is just the mechanical howl to tuffn her up.
More awesomeness!
KC
  #262
Old 01-30-2008, 06:42 AM
5th Grader
Default
Quote:
Originally Posted by cribbj View Post
KC, I don't know if you're following the ITB thread here: http://www.lextreme.com/forums/showthread.php?t=9322 The last day or so we've been talking about the potential for reducing lag in a centrifugal setup by using ITB's and tweaking the supercharger bypass valve. Might be an interesting read for you, or anyone else running a centrifugal.
I'll check it out. Currently, the car stumbles a bit between shifts with heavy throttle. I think the compressor surge may be the cause. Without the IC, I had a lot less surge and I can't recall having any shifting issues at all.
I am still planning on keeping the current setup but trying it without the IC to see what happens.
KC
  #263
Old 01-31-2008, 10:37 PM
5th Grader
Default
Quote:
Originally Posted by RedPhoenix View Post
Also, can you snap a few pics of the body mod you had to make for the FISH to fit?-Matt
Look at picture #15 on post 12. The area where the power distribution block is sitting is where it needs "modded". Like I said, it's a fairly significant amount of bashing that needs to be done.
Also, the fuse box needs to be MUCH furthur over than in that pic. The fuse box has been and still is one of my worst enemies though this whole thing.
KC
  #264
Old 01-31-2008, 11:43 PM
lexplay lexplay is offline
2nd Grader
Default
kc are the wire's too short to move the fuse box any where or is thier just no where else for it to go? i can see it getting in the way too.
  #265
Old 02-01-2008, 09:10 PM
5th Grader
Default
Quote:
The wires are not too short to turn the box and shove it over as much as possible. It's just a big PITA. It's really not a good thing to do to any fuse box. Ideally, it should be relocated. I don't know where to though. This would of course require extensive wiring.
I haven't really looked into it, but it may be possible to use a smaller fuse box. Aftermarket or OEM out of another Toyota. It may also be possible to custom make something. Even if it's just a small plastic box.
KC
  #266
Old 02-02-2008, 05:06 AM
2nd Grader
Default
gues ill find out shortly. Cause my cars a daily driver as well first thing im going to do is remove the original fan and put the electric fans on, move the battery to the boot, did u run a posative and a negative battery cable to the back? plus try fidle with that fuse box, im sure theirs something we can do with it.
  #267
Old 02-02-2008, 07:29 AM
RedPhoenix's Avatar
RedPhoenix RedPhoenix is offline
5th Grader
Default
you dont need to run a negative to the back. just ground out the battery to the chasis somehow
  #268
Old 02-02-2008, 08:40 AM
Lextreme's Avatar
Lextreme Lextreme is offline
Just call me "Lex"
Default
When u relocate the battery to the trunk. Make sure you solder the connection for good conductivity.
__________________
* 1993 SC470TT VVTi - Twin Turbo 4.7L Iron Block at work/Shine Project Body Kit
* 1995 LS520 - 5.2L Stroker with MeisterR Coil Overs and G35 19s
* 1998 GS400 - Daily Stock
* 1995 Previa - Supercharged Previa
  #269
Old 02-02-2008, 09:59 AM
5th Grader
Default
Hey guys,
I'm having a little drivability problem that started yesterday. I think the gasket I had made to block the EGR might have failed. Or I might have a vac/boost leak.
IfI manage to figure it out tonight, I'll make some more, longer driving vids on Sunday.
KC
  #270
Old 02-02-2008, 10:17 AM
mshawari1's Avatar
mshawari1 mshawari1 is offline
6th Grader
Default
Quote:
I agree with you.. That is an important point
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1UZFE Soarer engine into a HQ Holden Craig Swap, Conversion, Transplant, Specialty Vehicles & Project Diary (Members Only) 0 02-09-2006 09:37 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
