Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Forced Induction Tech (Members Only)
Custom Search
Forced Induction Tech (Members Only) Supercharged, Turbocharged, NOS, Intercooler, Methanol Injection & Go Fast and None OEM Stuffs.
Reply
Thread Tools Display Modes
  #251
Old 01-29-2008, 07:03 PM
kc95sc400 kc95sc400 is offline
5th Grader
Default
Quote:
Originally Posted by sonoramike
a quick down and dirty HP calc shows a 3800lb car with RWD and auto would take 400hp to do a 4.858756556460258 second 0-60 time
Quote:
Originally Posted by RedPhoenix View Post
but its no where near 400hp... id say 300ish.
I assume the 400hp estimate would be at the flywheel, which would be roughly 320rwhp. I think this is probably in the right neighboorhood.
The only similar setup I can compare to is the original SC400 fish install which belongs to George on this forum. http://www.lextreme.com/forums/showt...highlight=fish
He made 276rwhp with 5 psi. Main differences between his setup and mine, he is using a bigger blower (v1), but I am blowing in the 8-10 psi range.
A dyno will be the only way to know for sure of course. Before I go to a dyno, I need to do some tweaking to my IC setup, get my headers and install them, and do some street tuning.
BTW, I really like my current IC setup, but I have one more thing I need to try. Same pipe path as seen in the video but I want to put straight pipe in place of the IC. I am very curious to see what the temp difference will be between non IC pipe in the engine bay and non IC pipe not in the engine bay.
Khris
  #252
Old 01-29-2008, 09:01 PM
lexplay lexplay is offline
2nd Grader
Default
good to see its worked out ok for u kc. i just bought thermactors supercharger off him and currently am collecting up the rest of the parts to do it. im sure you's will hear more from me when i get closer to puting it on.
  #253
Old 01-29-2008, 09:50 PM
5th Grader
Default
Quote:
Thanks.
Very awesome to hear of another fish project in the works (thanks again Lextreme!) and that is one hell of a deal from thermactor.
On a side note, anyone considering a fish setup with a Vortech should keep an eye out for the V-9's on ebay. They are usually cheap compared to the V1s and the V2s, less demand for them. And depite a few people who thought that the V-9 is too small, and a few people who out right told me it's too small (including Vortech customer servie), I think I've proven that it works, and it works darn well to boot.
Khris
  #254
Old 01-29-2008, 09:57 PM
Lextreme's Avatar
Lextreme Lextreme is offline
Just call me "Lex"
Default
Honestly speaking, the Fish is the most affordable comparing to the rest of the FI system. I am glad u guys take it to the next step. Lexplay... Lets get it on!
__________________
* 1993 SC470TT VVTi - Twin Turbo 4.7L Iron Block at work/Shine Project Body Kit
* 1995 LS520 - 5.2L Stroker with MeisterR Coil Overs and G35 19s
* 1998 GS400 - Daily Stock
* 1995 Previa - Supercharged Previa
  #255
Old 01-29-2008, 11:28 PM
cribbj's Avatar
cribbj cribbj is offline
"Supra" Moderator
Default
KC, I don't know if you're following the ITB thread here: http://www.lextreme.com/forums/showthread.php?t=9322 The last day or so we've been talking about the potential for reducing lag in a centrifugal setup by using ITB's and tweaking the supercharger bypass valve. Might be an interesting read for you, or anyone else running a centrifugal.
__________________
High mileage, low compression, and sometimes not firing on all cylinders, just like my cars.....
New Daily Driver (Ferrari 550 Maranello)
Supercharged Supra Project
BMW V12 Project
2JZ-GZTE Project
  #256
Old 01-30-2008, 12:25 AM
2nd Grader
Default
it shouldnt be too long before i start so far i have got
fish bracket
bolt kit
v2 supercharger
oil t-peice
2x idler bearings
rising rate fuel reg
blow off valve
au thermo fan
all the piping and lines i will make up when its on the car. im not going to run a intercooler, its just going to be straight in.
do you think it will run with just the rising rate fuel reg plus a AEM wideband uego controller to see whats happening?
  #257
Old 01-30-2008, 01:47 AM
stevechumo's Avatar
stevechumo stevechumo is offline
Master
Default
I believe10 psi should give around 400 bhp, but not rwhp. On average and proven of 6 psi, the SC400 will make additional 80-90 hp. 10 psi should yield an additional 150 hp. The SC400 bhp is about 250. However, this depends on how the car is tuned. Rich condition will usually lose power, while just a little leaner condition will make more power.
__________________
Single Turbo SC400 15 psi (389 rwhp and +400 rwtq), AEM EMS, Lextreme Hi-Performance Torque Converter, Hi-Performance Built Tranny with Shift Kit, Tein SS Coilover, Supra LCA, Big Brakes, Stainless Steel Brake Lines, LSD, Strut Bar, And Many More.
  #258
Old 01-30-2008, 06:08 AM
1uzvl's Avatar
1uzvl 1uzvl is offline
3rd Grader
Default
Lexplay,i would be real keen to eyeball your setup when you get it done if you would like to show it off.Im at the stage of a turbo/supercharger showdown and i think the supercharger setup is winning.My vl is just begging for some boost and a nice vortech supercharger with the straight cut gears is just the mechanical howl to tuffn her up.
  #259
Old 01-30-2008, 06:36 AM
5th Grader
Default
Quote:
I'm afraid to go to lean, seeing as I'm probably already pushing the limits a little. Running 10ish psi without any fuel mods other than the MAFTPro, and I did also bypass the fuel pump ECU. I may actually un bypass the FPECU, I'm not sure I'm seeing any benefit from it.
I have the MAFTPro set for 12.5 with boost, it works great. But..when I first go WOT, it hangs around 10-11 to 1 for a second and I can definately feel the loss of power. Haven't figured out how to tune it out yet. I think I may actually have a boost leak somewhere after the MAF, but I haven't been able to find anything.
KC
  #260
Old 01-30-2008, 06:39 AM
5th Grader
Default
fish bracket
bolt kit
v2 supercharger
oil t-peice
2x idler bearings
blow off valve
au thermo fan
Awesome. FYI, with my car I was seeing IAT temps of 65-75 above ambient without boost when I had it straight in. From everything I have read, that is fairly low, but it was making my nervous. Otherwise, straight in had the best overall driveability.
KC
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1UZFE Soarer engine into a HQ Holden Craig Swap, Conversion, Transplant, Specialty Vehicles & Project Diary (Members Only) 0 02-09-2006 09:37 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
