Lextreme: Lexus-Toyota V8 Forum
Go Back   Lextreme: Lexus-Toyota V8 Forum > V8 Performance Tech > Forced Induction Tech (Members Only)
Custom Search
Forced Induction Tech (Members Only) Supercharged, Turbocharged, NOS, Intercooler, Methanol Injection & Go Fast and None OEM Stuffs.
Reply
Thread Tools Display Modes
  #141
Old 11-07-2007, 10:16 PM
kc95sc400 kc95sc400 is offline
5th Grader
Default
Quote:
Originally Posted by Boosted2.0 View Post
That is a nice looking H Beam rod. Is that a Carillo or an Eagle by chance?
If money was no object, these would be in my engine for sure.
KC
  #142
Old 11-07-2007, 10:26 PM
5th Grader
Default Parts
Guys,
Over the last couple of days I have taken possesion of some parts and I thought I'd share.
Intercooler piping. I kinda guessed at it, picked pipes individually. I'm sure some cutting and welding will be required.
Intercooler.
Bypass which will be vented to atmosphere before, and as far away from the MAF as possible.
This is the boost limiter valve I am going to try out. My only concern is that it will likely start opening before the desired pressure, unless there is some design element to prevent it. It's a pretty simple one way check valve. The "release pressure" is adjusted by turning the top threaded portion, which adds or relieves spring pressure.
More pics of valve.
Last but not least, AEM wideband.
I had purchase a cooling fan and clutch on ebay, the seller turned out to be a deadbeat. I am currently trying to re-source.
If I manage to have all the parts in hand by the weekend before Thanksgiving, I will by bolting this baby on!
KC
  #143
Old 11-07-2007, 11:28 PM
Blizzy Blizzy is offline
1st Grader
Default
Quote:
Your pace is astounding. Keep it up man!
I love that bypass set up. That is going to work (and sound) sweet.
  #144
Old 11-08-2007, 04:11 PM
Boosted2.0 Boosted2.0 is offline
1st Grader
Default
Great progress!
Beccas Grandpa is doing well so it looks like we will be in your neck of the woods for Christmas. We're going to try to finagle an extra day onto the beginning of the trip so we can get some time with you guys - we'll see how it goes.
  #145
Old 11-08-2007, 09:05 PM
5th Grader
Default
Great progress!
Dave,
Glad to here your Grandpa-in-law is doing better.
KC
  #146
Old 11-08-2007, 09:37 PM
Lextreme's Avatar
Lextreme Lextreme is offline
Just call me "Lex"
Default
KC,
How many cfm does the pop valve flow?
__________________
* 1993 SC470TT VVTi - Twin Turbo 4.7L Iron Block at work/Shine Project Body Kit
* 1995 LS520 - 5.2L Stroker with MeisterR Coil Overs and G35 19s
* 1998 GS400 - Daily Stock
* 1995 Previa - Supercharged Previa
  #147
Old 11-08-2007, 10:42 PM
5th Grader
Default
Quote:
Originally Posted by Lextreme View Post
KC,
I have no idea, but I'll be sure to report on how well it works.
KC
  #148
Old 11-08-2007, 10:57 PM
Lextreme's Avatar
Just call me "Lex"
Default
It is important to know because if the valve flow say 5 psi and you are boosting 15 psi and that mean you will get 10 psi max. However, you goal was to run 6 psi.
__________________
  #149
Old 11-10-2007, 08:44 PM
MightyAl MightyAl is offline
Kinder
Default
psi and cfm are two different things. Maybe I am lost here but psi would be the issue right??
  #150
Old 11-11-2007, 06:31 AM
1st Grader
Default
Quote:
while the spring rate will determine when the valve opens, and that solely a product of pressue (psi)...the valve likely has a maximum flow capacity as well (cfm), which could result in some boost creep.
ultimately, I would bet that the valve is capable of blowing off sufficient cfm to prevent boost creep for this application.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1UZFE Soarer engine into a HQ Holden Craig Swap, Conversion, Transplant, Specialty Vehicles & Project Diary (Members Only) 0 02-09-2006 09:37 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
